Hooker 2460 & dual-cats?
Old Oct 22, 2006 | 02:48 PM
ecetim's Avatar
Car: 92 RS B4C - needs lots of work!
Engine: 5.7L L98
Transmission: 700R4?
So I think I've decided on the final exhaust for the 92 B4C. Thing is the B4C comes with dual cats. I'm not worried about the performance difference between single high-flow vs dual stock cats, cost and pollution are at the top of my list.
The car had its AIR system removed already, so here's what I'm thinking:
  • Hooker 2460's
  • Custom y-pipe
  • Dual factory cat's
The y-pipe for the 2460's is like $200 and I'd have to get a new single cat to work with it. The guy who would be doing my exhaust work won't quote me on a custom y-pipe until he sees the headers, since he's not sure what kind of work he'll have to do. I'm figuring even if a custom y-pipe runs $300, that will be $160 (headers) + $300 (custom y) for total of $460 and keep the dual cats. If I got the Hooker y-pipe it would be $160 (headers) + $200 (hooker y) + ~$100 (new cat). As long as this guy can make a good y-pipe, I think I'll be set.
I think I'm also going to add a Spintech cat-back if I can get one at a decent price.
Comments, suggestions, concerns? My priorities in order are: Price, pollution, exhaust sound quality, and performance. Fact of the matter is for a stock L98 the difference in headers and exhaust won't make a big difference, esp since it won't be raced at all.
Thanks!
Old Oct 30, 2006 | 06:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If pollution is part of the equation, why did you eliminate the A.I.R.?
If you insist on the 2460's, get the Hooker y-pipe, have it modified (cut before the actual "Y") to connect to your dual cats. Better bends (mandrel) than an exhaust shop custom y-pipe, simple to connect to the cats.
You could go with the 2055's and have it's y-pipe cut to connect to the dual cats. But, the above isn't too bad of an alternative.
Old Oct 30, 2006 | 06:10 PM
ecetim's Avatar
Engine: 5.7L L98
I didn't eliminate the AIR, car came that way with a rebuilt motor (which we found out after purchase).
I was looking at the 2460's simply because of their price and can get a custom y-pipe made, hopefully coming out cheaper overall with keeping dual cats.
So how well does the modified Hooker y-pipe work? Is that probably the easiest route to go then? 2055's aren't much more than the 2460's+y-pipe, and its a better setup from what I read. Either way, the guy needs to see the headers to tell me how much a custom y-pipe will be.
Old Nov 2, 2006 | 09:48 PM
five7kid's Avatar
Hookers and dual cats haven't been discussed much here that I've seen. I can only recall hearing of one member who has done the 2055's with dual cats, and I seem to remember that he said it worked very well.
It seems most people that start out with dual cats and use 2055's just put on a single 3" high-flow cat. I've considered going the dual route and modifying as indicated, but I haven't been able to justify it to date.
Most reports of 2460's and custom y-pipe either end up costing as much as the 2055's, or with a pitiful y-pipe, or all to often, both.
jrdturbo
Mar 31, 2016 02:58 PM
no green
Jan 9, 2016 09:22 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
