Some Thing Cheap To Wake Up The Neighbors?
Car: 88 Camaro Sport Coupe
Engine: 305 TBI
I needs some suggestions for something like under a 100 (if there is such a fix) dollars to make some loud noises that **** the parents off
(not illegal my mom would probably tell the cops)
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
you can pick up a exhaust cut out really cheap just clamp one in........
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Cut out would do it, that's about all you're going to get for under 100. But make sure that head gasket gets done first.
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
cut off stock muffler and gut stock cat converter. then add dynomax bullet for 30-40 bucks.
thats loud
thats loud
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 1987 IROC
Engine: 350 Gm H.O
Transmission: 700r4 built
Axle/Gears: 3.42 Locker
"Besides hacking off your muffler I'd suggest an electric cutout."
Electric exhaust cutouts cost alot more than $100 and it has to be installed. But they are alot more efficient and don't leak. I know somebody that has them on there nova and they work really good.
Car: 02 Mustang
Engine: 3.8 about to be punched out to 4.3
Transmission: 4R70W
Axle/Gears: 3.73 Detroit true trac
sorry to hijack but has anyone heard of the flowtechs at summit? or any clips of em these
Car: '87 IROC-Z
Transmission: Comatose 700R4
Axle/Gears: 10 Bolt Posi 2.73
Again, thats what Ive heard and not what I've experienced.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
cheap and loud?
just run open heads...
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
Car: 02 Mustang
Transmission: 4R70W
Car: 88 IROC
if you dont have any headers and just run off the heads it will fry your valves because the mixture will still be burning on its way out. i think its because there would be oxygen right there at the valve and thats what burns em.
i could be wrong on the explanation but i know that no headers=burned valves
Car: 02 Mustang
Transmission: 4R70W
