Cat-Converter???
Old Dec 8, 2006 | 07:45 PM
85TransAmDude's Avatar
Car: 1985 Firebird Trans Am.
Engine: 305 H.O. 4bbl
Transmission: 700R4.. I think
Axle/Gears: Not Sure, 3.73?
Cat-Converter???
Hey..was just wondering...does your car need a cat-converter to pass a motor vehicle inspection in Newfoundland, Canada?
Old Dec 9, 2006 | 10:04 AM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
If I was you I wouldn't bother removing it if thats what your thinking about doing. Just get a high flow there cheap and you wont notice a difference in power.
Old Dec 9, 2006 | 12:53 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I agree with crrllmich..........I have thrush cats here in Ontario and I pass the sniffer and there is no loss of power. There are lots of low restriction aftermarket and original GM ones that will work. See if the boneyards have any from a late model vette for starters.
Old Dec 9, 2006 | 06:48 PM
Alright well my father alredy cut the old one out cause it was rotted out...so i have no cat at all...as for one of thoes high flow cats...how much would i pay for one?...also how much do you think it would cost to get it put up?...would i be able to special order one from canadian tire in the special parts order?..thanks
Old Dec 10, 2006 | 05:13 AM
Car: 89 IROC
You would have to check with your parts store and muffler shop for pricing. I believe cdn. tire can help just go in and tell them what you want and price out installation as well.
Old Dec 10, 2006 | 10:07 AM
gray89vert's Avatar
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
i got my magnaflow for about 60
