Hooker 2055 Ceramic Coated vs painted?
Old Dec 31, 2006 | 09:56 AM
patricktroyz28's Avatar
Car: 1991 Z-28
Transmission: 4L60
I understand the painted ones will be rust color 10 seconds after install, but is there any other benefits of getting the ceramic coated ones that looks? I can't send them to jethot to get coated, because I am buying them in Canada and it would cost a small fortune to ship them back and forth, so is it worth spending the extra $400 and order then ceramic coated vs painted, $775 vs $400?
Tks Troy
Old Dec 31, 2006 | 11:37 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Uncoated or painted headers are about 500-600 degrees. Coated headers are about 300-400 degrees. The coating also helps the headers last longer, and they do look better.
Old Dec 31, 2006 | 12:31 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i had painted when i first put the car togeather and now i have coated and the temp difference of the engine bay is noticable.
Old Dec 31, 2006 | 12:37 PM
Car: 1991 Z-28
Transmission: 4L60
Well I guess its worth to spend the couple of extra now to save in the long run..bought the car new, so I can't see getting rid of it anytime soon.
Tks guys for the input!
Old Dec 31, 2006 | 01:32 PM
Gramps's Avatar
Car: 87 Camaro IROC
better exhaust velocity and even temp control. keeps your engine bay cooler which results in better hp and torque.
Old Feb 4, 2007 | 10:38 PM
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
You can get ceramic coating done here in Canada as well. I have had Top Gun cermic coat headers for me before and they turned out very nice. Check it out here
http://www.topguncoatings.com/index.html
As mentioned it will keep your underhood temps lower and provide long lasting looks.
Old Feb 4, 2007 | 11:01 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Coated headers are well worth the money. As well all know quite a few of the parts on our cars are plastic and heat usually makes plastic brittle. Coated headers will not only reduce engine bay temp but also make lots of the parts in the engine bay last longer.
Plus they look cool too!!
Hotrodboba400
Dec 10, 2019 07:07 PM
Stryker412
Sep 7, 2015 09:11 AM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
