painting cat-back systems.
Old Dec 31, 2006 | 01:35 PM
Gramps's Avatar
Car: 87 Camaro IROC
i did not want the cliche stainless exhaust because i know a polished stainless exhaust will tarnish after a few days of driving, and its very hard to keep it polished (im @nal like that). so i bought a mild steel kit and planned to paint it but was wondering what methods and products you guys used.
any help would be great because i do not wanna have to go to a shop to ask the questions.
thank you
Tony
EDIT: the colour im looking to paint is flat black, from the y-pipe to the muffler (i got stainless tips).
Old Jan 1, 2007 | 03:23 AM
ws6gta89's Avatar
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
if you really wanted it to be durable then why not get it powder coated or use a high temp engine paint
Old Jan 1, 2007 | 04:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
High temp paint would be better. Powder coat probably wouldn't last close to the cat.
You can get ceramic coating in black.
To paint it, you need to sand blast it clean, solvent clean the surface, then paint. It's best to bake it after painting to cure before being subjected to exhaust heat. Hard to find an oven that big, though.
Old Jan 1, 2007 | 05:29 PM
danjanIROCZ's Avatar
Car: 1990 IROC-Z
Transmission: 5 Speed
You could do what five7kid suggests, but as far as the baking part goes, instead of trying to squeeze it into an industrial size oven, you could probably just hit it with a propane torch to cure the paint.
Old Jan 3, 2007 | 02:51 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
If your after durability, also make sure to drill a small weep hole on either side of the muffler. This helps drain all the water out of it and keeps it from becoming a hollow steel can.
Old Jan 3, 2007 | 03:45 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
prep it by making sure its very clean... right now, it has oil on it to prevent rust.
use brake cleaner or paint prep solvents
once you get to the straight section of the Ipipe, you dont need any kind of high temp paint. regular paint works just fine.... but you can use whatever.
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Sep 21, 2015 08:54 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
