Heddman lt's question
Old Feb 20, 2007 | 03:32 PM
1970judge's Avatar
Car: 86 IROC-Z
Engine: LB9 5.0 tpi
Just ordered the heddman lt's. My motor is out of my car should i bolt them to the motor now or later? I am going in with motor and transmission at the same time since i made room up front. SO, which is better now or later??
Old Feb 20, 2007 | 04:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Mine went in easy enough with the engine in the car.
Old Feb 20, 2007 | 11:23 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
I would be shocked it the entire assembly when in assembled. I would thing put the motor and trans in in one shot and the headers in next.
Old Feb 20, 2007 | 11:34 PM
1970judge's Avatar
Car: 86 IROC-Z
Engine: LB9 5.0 tpi
Roger that, thanks guys!
Old Feb 20, 2007 | 11:35 PM
Comp788's Avatar
Let us know what you opted to do and how it all worked out.
Good luck!
Old Feb 21, 2007 | 01:14 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
good question i kinda wondered about whether you could successfully drop a sbc engine in with LT's bolted onto it or not
i found a place in springfield with a good running 305 in an 83 caprice i am gonna get it for a couple hundred if they still have it hopefully and i have a pair of LT's that i hope will fit the car, since my stock exhaust is gone and has been since before i got the car, i should take pics of the pair of LT's i have here and see who thinks they will or wont fit and why or why not
good luck
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
