4 inch cat?
Old Mar 28, 2007 | 08:33 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
4 inch cat?
are there any companys that make a 4 inch cat. converter ?
Old Mar 31, 2007 | 12:16 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Re: 4 inch cat?
Not that I am aware of.....your only option would be a hiflo 3" with the inlets and outlets opened up, or you could look for some factory 3" cats that have a larger (taller) body...then cut off the inlets and outlets and weld on some 4" nipples. Some of the truck cats (pick-ups) have a large enough body that you could do that but you may run into clearance issues getting them on you car.
Old Apr 1, 2007 | 02:37 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 4 inch cat?
I thought Magnaflow recently came out with some, but I couldnt find it on their website. Maybe you'll have better luck.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Night rider327
Oct 9, 2015 09:25 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
gord327
Sep 29, 2015 10:18 PM
Night rider327
Sep 25, 2015 04:47 AM
