cant take header problem
Old Apr 6, 2007 | 10:37 AM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
i recently have been searching for a set of headers for my 89 rs 305 tbi. i cant find them anywhere. my budget is quite tight so i was looking used..idc what kind they are i just keep hearing they wont fit on my car or something about angled plugs??? i dont even know if i have angled plugs...please if anyone has any or any info it will be honored
thanks
blimko
Old Apr 6, 2007 | 11:45 AM
88 Z28 Guy's Avatar
Car: 1989 IROC
Axle/Gears: 3.42 Auburn
Re: cant take header problem
Well for headers I like Headman. Hookers are considered a little better but not worth the extra $ in my opinion. Well you can get longtube headmans (summit part HED-68460). But note with longtubes you have to lift the motor to install. Another good option, not as good performance wise are shortys (summit part HED-68470). With shorties you can buy aftermarket y pipes, also from summit but im pretty sure your stock y pipe will work if not you can find shorties that will work with the stock y pipe.
As far as angle plug heads, in pretty sure you dont have them. Regular heads, the plugs screw straight into the head, Angle plug heads, the plugs screw in at an angle.
Old Apr 6, 2007 | 02:24 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
do not get a hack it up y pipe header. i made that mistake with buying dynomax blackjacks and they dont make a ypipe go figure so youre suppossed to cut weld or clamp your old ypipe to fit i looked at it and i find no way of it working. returned the crap bought hedmen with their matching ypipe. a lot better and still pretty cheap around i think 250 for all from jegs.
Old Apr 7, 2007 | 01:13 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Hookers fit......that alone is worth the extra money!
Old Apr 7, 2007 | 01:19 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
so hooker or hedmen? its gotta be somewhat cheap unless you guys know someone who may know someone with headers for sale
Old Apr 7, 2007 | 02:29 PM
Engine: LO3
hedmens are cheaper and just as good
Old Apr 7, 2007 | 09:53 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Hedman, hooker and edelbrock (and probably a few more) all sell y-pipes to match their headers...
Street Lethal
Apr 30, 2019 12:14 PM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
