Full Exhaust System
Old Apr 7, 2007 | 01:27 PM
Ucantcme57's Avatar
Full Exhaust System
Does anyone make a complete exhaust system for 82-92 camaro from the headers back? Would like an x-pipe and tail pipes out the rear? Any one have any ideas other than a complete fab?
Old Apr 7, 2007 | 09:50 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: Full Exhaust System
The only thing you can buy "bolt on" is a stock stlye exhaust.
You can get the shorty headers and a Y-pipe with them to fit the stock locations. Then a catback setup of your choice.
Other than that dynomax sells a ghetto full dual system to work with their shortys but its only 2.25" tube and is supposed to be bad for ground clearance and doesnt feature any H or X equalisation setup.
If your looking for true duals its going to be a fab job!
Old Apr 8, 2007 | 08:21 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
To my knowledge no aftermarket company makes a complete stand alone exhaust kit that replaces everything from the motor to tail pipe. There are however many companies that make the necessary components to piece together an entire system. You can even mix and match which is commonly done with great success. You just want to make sure you order everything tailored for an 86 or later TPI car. That way everything comes 3" will all necessary 3" mating surfaces/flanges. For instance, you could buy (insert cat-back of choice) and bolt on a Cat-Co TPI replacement 3" cat (9118 I think) and then slip it onto the y-pipe that comes with the header kit of your choice.
I have run
Hooker cat-back
Cat-Co 3" cat
Flowtech headers with 2.5" reducer to mate to 3" cat (flowtechs do not have a 3" y-pipe)
I now run
Hooker cat-back
Cat-Co 3" cat
SLP headers
Three brands but all for TPI applications that bolted together.
Old Apr 9, 2007 | 10:21 AM
Ucantcme57's Avatar
Does this Cat-Co make a pipe to replace the Cat?
Michigan, no smog/cat converter rules...
Old Apr 9, 2007 | 10:48 AM
pinky93's Avatar
Car: 1989 IROC-Z
Engine: 5.7
Transmission: 700R-4
Axle/Gears: 9-Bolt Borg-Warner 2.77
I saw some posts somewhere with pictures of a full exhaust system w/ crossover pipe and true duals. Do a search. If I remember correctly, it still even had some ground clearance!
Old Apr 9, 2007 | 03:55 PM
Ucantcme57's Avatar
I want those huge hooker headers, like part # 2201 or something.. It doesn't matter if I go true duals or a single after the x or y pipe, I just need max. outflow, very nonrestrictive.. a supercharger is in this motors future..
Street Lethal
Apr 30, 2019 12:14 PM
69 Six Pack
Oct 5, 2015 07:51 PM
tcflint
Exterior Parts for Sale
Aug 26, 2015 05:45 PM
makaveli09
Aug 12, 2015 09:07 PM
