Headers to Match AFR Eliminator 195 Port
Old Apr 14, 2007 | 10:10 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Hi folks,
I received Fel-Pro 1404 exhaust gaskets with my AFRs, and the gasket matches the exhaust ports nicely; does anyone know how well this gasket matches up to Hooker 2055 headers? I am trying verify cylinder head exhaust port to header opening match up. Would like to get Dyno Don's headers, but I get no response to phone messages or PMs or e-mails (hello...Don...hello?).
Thanks for the help.
Bill
Old Apr 14, 2007 | 10:36 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not perfectly. The best bet would be to gasket match them. The best way to do that is to MIG weld around the tube on the outside of the flange, then you can open them up without worrying about grinding away the tube-to-flange weld.
I got away with just blending the corners to the gasket, but it isn't perfect. With bigger heads like the 195's, you might want to go the full weld/clean-up route.
Old Apr 14, 2007 | 10:49 AM
Burnout91's Avatar
Engine: Modded L98
Re: Headers to Match AFR Eliminator 195 Port
five7kid,
Thank you for your input. Did you use Fel-Pro 1404, or the Hooker gaskets? I called Hooker tech to ask if the 1404 matched the header, they said, "Don't know, we don't use Fel-Pro gaskets".
Bill
...P.S.: Are you happy with the Hooker 2055s?....with no word from Dyno Don, I'm getting ready to order the Hookers next week.
Thanx again,
Bill
Old Apr 14, 2007 | 11:30 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Bill:
I did respond ....10 sets are in the works, but I can't say when they will be ready. (I have to rely on the bender for the tubes).
2055's will cover part of the port=bad! Besides, they're 1 5/8's
Old Apr 14, 2007 | 11:37 AM
Burnout91's Avatar
Engine: Modded L98
Thanks much for the reply, Don. I will wait for the BEST parts (always the right thing to do...). Getting ready to do heads, cam & new headers....I am anxious, but not impatient. 'Got my VISA in hand.....just say the word!
Bill
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
willyjoejr
Sep 3, 2015 09:26 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
