A.I.R. with open element filter, question inside
Old Apr 20, 2007 | 07:38 PM
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
Last year I swapped in an open element filter, and now it's time to finish the upgrade on my exhaust (new headers, y-pipe and cat). Should I get a system that has AIR since my car originally came equipped with AIR, or can I bypass this somehow (as it's not really being used correctly since the driver side manifold is open now.
as far as headers go, I see so many mixed reviews for shorties (my car is too low for long tubes), unless something has come up since I last read through all the header threads, is there anything I need to watch out for?
Thanks for your time and consideration.
Old Apr 21, 2007 | 12:24 AM
Grim'91Z's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7L V8
Transmission: 700R4 Auto
Re: A.I.R. with open element filter, question inside
Does your state require them?
Old Apr 21, 2007 | 06:11 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I would keep air, it is better for the environment and less work since you already have it, air is injected in your cat converter to reduce exhaust gasses by allowing them to be more effectively burned. The thermac valve you removed by installing the open element has nothing to do with the air sistem, it only lets warm air in when the engine is cold to get it warmed up faster.
Ceramic coated would be best, it keeps the engine compartement cooler.
Mac-performance and Hoocker seem to be the performance and install friendlyest.
Old Apr 21, 2007 | 12:55 PM
thank you for clearing that up
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
wruiz
Aug 13, 2015 09:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
