89 Trans Am GTA cat back system
Car: 1989 Trans Am GTA
Engine: 350/L98
Transmission: 4 speed auto
Axle/Gears: 3:27
I have a 89 GTA with a 5.7 and dual cats. Does any one make a cat back system with two tail pipes thats not $500? I have seen the Flowmaster single tail pipe system for about $260 from summit. Has any one used this set up?
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
Re: 89 Trans Am GTA cat back system
HOOKER!, WAY BETTER THAN BLOWMASTER, BETTER SOUND AND PERFORMANCE. AND TWO REALLY NICE LOOKING TAILPIPES. DO A SEARCH.
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
i believe dynomax makes one for around 200 or so but really is the same config as stock with a little better sound
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The cat-backs are similar, regardless of your cats. You're going to want a muffler shop to make the connection between your cats and the i-pipe, anyway. So get whichever system you like the sound of, and have it installed. No matter what they say in their advertising, nothing bolts together in your driveway and works perfectly.
SLP used to make a BOLT together cat back, that truely does bolt on in your driveway. The N10 Dual cats have a hog clamp that connects the cats to the intermediate pipe. It's a nice 3" cat back, with a straight through muffler, twin pipes exit on left side.
Maybe they'll make you up the system. It's not on their web site anymore, but I'm sure they still have the prints.
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
My Formula with dual cats has a Flowmaster American thunder catback on it. It was purchased at summit. I can dig up a part # for you if you want.
