Need some exhaust help
Car: 92 z28
Transmission: auto
I have a 92 Z-28 that I want to redo the exhaust of. I'm planning on buying the hooker 2460 headers(2460HKR), y-pipe for it(16767HKR) and the hooker super competitioon cat-back(16823HKR). I am having trouble picking which Catalytic converter i need. The rest of the system is 3 inches so it needs to be as well and I cant weld so it needs to be direct fit. The ones Ive been finding for the camaro are not 3" and the one I find with 3 inches don't seem to be direct fit. Also how does a slip fit work? do the two pipes over lap and use some kind of clamp or something. I am just looking for the cheapest cat that will bolt right in. Any help is greatly appreciated
Car: 92 z28
Transmission: auto
Re: Need some exhaust help
how much more power can I expect to gain from this set up if I do a cold air or ram air intake as well
Last edited by Dolfan348454999; May 28, 2007 at 06:44 PM. Reason: want to know power added not overall
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Yea i got the same headers and y pipe, you can use a universal 2.5" cat and modify the pipe that bolts to the y pipe(included with y-pipe) or just not run a cat at all like me!
Car: 91 formula ws6
Engine: 1 peice roller scat 383 4 BOLT!!
Transmission: 5 speed
don't cheap out on the cat,, if your even gonna bother with one.
if you cheap the cat, you waste the nice headers and exhaust.
Check magnaflow for cats
Engine: 355
You have an Off-Road y-pipe not setup to run a cat, the entire ypipe is 2.5" you will need to run a catalytic convertor that will flow enough to support your cubes. The only magnaflow convertor that will work is 3" in diameter therefore you'll need to run a dynamax superconvertor or the like.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's a suggestion (one that may not be of interest, but it is a direct fit):
Hooker 2055's (Jeg's 520-2055). Catco high-flow converter (Summit CTO-9118). Hooker catback (Summit HOK-16823HKR).
JamesC
JamesC
david068513
Sep 18, 2015 10:36 AM
