ls1 question
Old May 30, 2007 | 07:58 AM
DerrickB4C's Avatar
Car: 1991 CAMARO RS
Engine: 305TPI SOON TO BE 350 TPI
Transmission: 5 SPEED
Axle/Gears: STOCK FOR NOW
ls1 question
is the bolt pattern for the exaust manifold the same from gen one to the ls1?
Old May 30, 2007 | 09:05 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Re: ls1 question
no
Old May 30, 2007 | 09:14 AM
DerrickB4C's Avatar
Car: 1991 CAMARO RS
Re: ls1 question
know where i can get the flange?
Old May 31, 2007 | 07:58 PM
gunz4life2's Avatar
Car: '91 Firebird
Engine: 305 TBI
Re: ls1 question
I'm not sure if this applies to cars, but I heard that the truck guys are modifying big block headers to fit GenIII's. I'm not sure where to buy the flange though. You could probably make one by tracing the exhaust gasket onto some metal then cutting it out(or something like that). You should be able to get the gasket from a junkyard for $1. Hope that helps some.
Old Jun 5, 2007 | 01:43 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Re: ls1 question
google LS1 header flanges, there are tons of sites that sell em
Old Jun 5, 2007 | 07:08 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: ls1 question
Its been done with 3rdgen BBC headers to use on an LS1. There was a pretty detailed thread on it. Should be able to find it if you search. Basically whats involved is getting the 3rdgen BBC headers, cutting off the head flanges, and welding on the LS1 flanges (and tweaking the tubes as necessary to fit up right).
Why not just use the F-body LS1 exhaust manifolds though? They flow extremely well for a cast iron manifold... most stock LS1 F-cars will LOSE power going from the iron manifolds to a shorty header, and only very mild gains with long tubes. The LS1 F-car iron manifolds are quite good. Much better than what the 3rdgens and LT1 cars got. Unless you have some talent and patience for fabrication, I'd suggest just sticking to the iron manifolds for a '98-02 Camaro or Firebird with LS1.
Old Jun 6, 2007 | 07:25 AM
DerrickB4C's Avatar
Car: 1991 CAMARO RS
Re: ls1 question
im going to weld up some turbo headers.
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
