Passenger side header pinned to the frame...
Old Jul 27, 2007 | 12:05 PM
89-IROC-Z's Avatar
Car: 1989 Iroc-z t-tops
Engine: carbed 305 +/- 450hp
Transmission: TH-350
i got a 89 Camaro used to be a v6 ..but now has a 305 v8 and had all the iroc-z body parts..anyway i put some headers on it those cheap flowtech headers this is the link..
http://store.summitracing.com/partdetail.asp?
autofilter=1∂=BIG%2D11116FLT&N=700+4294908216+
4294923429+4294839039+4294908198+4294924930+115&autoview=sku
the header just barely fits on the passenger side b/c the flange is against the frame and and that makes it leak ive stuffed gaskets in there for a temp fix. but i need to fix this bout the only thing i know to do is heat up the bends of the header and bend them till they fit or notch the frame.. anyone had this problem before? is so what did u do?
Old Jul 27, 2007 | 12:16 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Passenger side header pinned to the frame...
that flange can rotate a little to give you more clearance, if not dent the frame rail or put in new motor mounts if yours sag, etc etc
Old Jul 27, 2007 | 12:25 PM
89-IROC-Z's Avatar
ya i rotated it that didnt give enough space need just alil more you say dent the frame? would that be better then notching it out?
Old Jul 27, 2007 | 04:53 PM
xpndbl3's Avatar
Car: 1984 Z28
yes take a ball peen hammer and just give it a whack, it'll bend in the amount needed no problem, don't cut the frame rails over the cheapest headers known to man.
Old Jul 27, 2007 | 07:15 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
You need new motor mounts. Did you replace the v6 mounts when you added the v8? you shouldnt have to dent anything.
Old Jul 28, 2007 | 09:23 PM
89-IROC-Z's Avatar
ya i replaced them i dont think that the v6 motor mounts would work at all...its probly just these cheap headers..
so it looks like im gunna have to dent it a good bit are you talking about heating it up with the torch and denting it? or just beating it to death till it fits? lol (sorry i dont do alot of metal work)
Old Jul 28, 2007 | 09:50 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
If you dent a 1 1/2 inch header you might as well not run it. I had the same headers and they fit fine.However, They didnt add any noticable performance at all and raised my under hood temps in the process. I had this problem wiith a set of heddman headers and when i replaced the squishy old motor mount with a poly mount it fit fine.
V6 mounts fit the v8, I had to use them a few years back when I was in a pinch.
Old Jul 28, 2007 | 11:29 PM
89-IROC-Z's Avatar
im talking about denting the frame not the header and i doubt that bushings will help its not too high or too low its just too far to the left (passenger side) and headers do give more power if what u had on it was old manifolds, sounds better too lol
Old Jul 29, 2007 | 12:08 PM
xpndbl3's Avatar
Car: 1984 Z28
if it's more than 1/4" you have some issues.
Old Jul 29, 2007 | 12:24 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
I wouldnt go denting your frame for a set of 100$ headers. If the flange is the problem why not grind it down a little?
Old Jul 29, 2007 | 07:24 PM
89-IROC-Z's Avatar
i dont think its more then 1/4 but its not like im modifying a 1st gen frame lol i wouldnt dare lol im just wonting things to work this car is just a toy not a every day driver. ill just dent the frame it should probly be fine after that.
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
Wesly_66
Aug 26, 2015 09:55 PM
Cameeeero
Aug 20, 2015 03:06 AM
Street Lethal
Aug 14, 2015 08:25 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
