This might sound stupid but.....about mandrels....
Old Jul 30, 2007 | 12:12 AM
Bazookajoe254's Avatar
Car: 86 Firebird
Engine: 2.8 V6
I know mandrel bending like about 33% more efficient than the crush bending....but what about this bend? (attachment) I'm not asking because of an intake, I'm just using it as an example. The pipe isn't crushed together like a stock exhaust bend, but it also isn't the same diameter the whole way through, which if I'm correct, a mandrel bend is.
The space inside the pipe should still be the same, right? Except oval?
It might not flow as efficiently as if it were a perfect circle all the way through, but this change seems pretty small to decrease flow by a whole lot.
So if I used 3" piping and had it bent like the attached intake picture, it would probably flow well enough for an exhaust on a 2.8 V6, right? Just thought it might be a cheaper alternative to consider. The engine isn't HEAVILY modified, but I do want to have a little fun with it.
Attached Thumbnails This might sound stupid but.....about mandrels....-firebird006.jpg
Old Jul 30, 2007 | 12:26 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: This might sound stupid but.....about mandrels....
It is what it is, mandrel bent intake parts have a more unchanged path.
Old Jul 30, 2007 | 07:13 AM
kcgperformance's Avatar
Car: 88 RS Camaro (Z28 Clone)
Engine: LS6, Vengeance VRX5
Transmission: T56, LS7 Clutch
Axle/Gears: Moser 12 bolt 3.73:1 ratio
A 3" exhaust is extreme overkill for a 2.8L. I suggest that unless you plan on swapping some kind of V8, or turboing your 6, stay around 2 1/4" -2 1/2". it will give you some back pressure and help you immensly on the low end torque. Also you will maintain good exhaust velocity and that will help you make a few more ponies due to the effects of exhaust scavenging. So what I'm saying is if you must make it sound better get a replacement muffler such as flowmaster or dynamax in the stock exhaust diameter.
-Kevin
Old Jul 30, 2007 | 12:52 PM
Car: 86 Firebird
Engine: 2.8 V6
Yeah. I'm thinkin about gettin the 2.5" Dynomax catback from Summit. Only $170, and if I really don't like the sound (it says it sounds somewhat stock) I can just use the muffler I allready put on my car. Its a Flowtech...probably not the best flow, but I like the sound even with the stock pipes.
So that bend in the picture is not a mandrel bend? Thats what I thought, but it still doesn't look too bad as far as flow for an exhaust.
Old Jul 30, 2007 | 10:26 PM
It should sound better than the flowtech IMHO. Keep in mind that if this is a project car with V8 aspirations then you might just want to hold off and get something that will look sound and flow best with the larger displacement motor. I'm a big "Do it Once" kind of guy. I don't see a reason to go through 3 different exhausts on 2 different engines before getting what you want in the end. May as well just save the $$ towards the end result.
-Kevin
Old Jul 30, 2007 | 10:34 PM
Car: 86 Firebird
Engine: 2.8 V6
That's true. But I'm just goin into my senior year in highschool. If this car even makes it with me through college, and the beginning of a family and all that, only then would I consider dropping in a V8.
So for now, I really do think this would be a one time deal. If it does happen though, I know it'll be years and years and years later.
Hope I still have my car then.
Old Jul 30, 2007 | 11:10 PM
AC's Avatar
AC
Car: Used to drive a camaro
Bazookajoe, think positive!! I bought my first 3rd gen 2yrs after HS @ 19 yr's old. I turned that 42k mile 84Z H.O. into a 375 horse screamer only to flip it on it's roof 4 yrs later (don't ask how), bought 2 more during a 3 yr span only to buy my 4th and last 3rd gen, the one I have now which I've been buying parts for and building....all the time supporting mortages and a 6 person family!!!! Best of luck
Old Aug 2, 2007 | 06:57 PM
¡MR.AWESOME!'s Avatar
Car: '92 RS
Engine: 305 TBI
That's actually how my exhaust is bent. I bought the car from a self proclaimed "mechanic" and one of the horribly done mods to the car was the exhaust. I noticed it and thought, "How cheap can you get?" but if cheap is what you're going for, then sure, it would probably work better than crush bending.
Old Aug 2, 2007 | 07:08 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
That intake tube in the first pic isnt mandrel bent, its press bent. Thats how all the exhaust shops around here do it, but they call it mandrel bending.
Old Aug 3, 2007 | 06:06 PM
TeknoMaeg's Avatar
Originally Posted by slow_90firebird
That intake tube in the first pic isn't mandrel bent, its press bent. That's how all the exhaust shops around here do it, but they call it mandrel bending.
You see... that is the funny thing about the types of benders. Most shops that even produce bends aren't necessarily Mandrel benders. They are simply CNC Pipe Benders (Radius Benders). What defines a Mandrel Bender is the attachment to feed pipe. Usually is 5' additions. A mandrel will cost far more due to the fact you can design a pipe in the system. Insert the proper length of pipe for the job and hit start. Come back a few minutes later and you have a completed exhaust pipe.
What you have on your intake is in fact a traditional press bend. It is caused by two arms bending the pipe over an anvil or radius. Mandrel draws in the pipe to a Radius Bender and since it wraps around the entire pipe there is no where to flex but where the mandrel is pressing it.
As far as efficiency... that "bulge" caused by the press bend can cause turbulence and tumbling in your air stream... and the answer is YES... it potentially can cause a loss in power similar to a crush bend... but not as drastic.
Old Aug 12, 2007 | 03:31 PM
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
take a look at the Burns Stainless catalog to see what pieces of mandrel bent tubing look like.
I had my head stuck under the hood of the car from my teens through my 40's. completely missed the "beginning of a family" part, missed the boat. oh well. good to see you're thinking ahead.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
djmarch
Oct 2, 2015 10:41 PM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
