82-87 headers on a 91?
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
is it possible to put headers meant for a 82-87 camaro on my 91? What's the difference? can they fit? appreciate the help!
Transmission: 4L80E/4L80E
Which headers are you talking about? Pretty rare to have them spec'd for '82-'87.
But, no difference in the exhaust ports or chassis, so as long as you don't mind some fabrication of the rest of the exhaust, they'll fit.
Transmission: 4L60
Re: 82-87 headers on a 91?
well i found out they are for H.O., does that matter?
"HO" would be '83-'86, and for all practical purposes, '83-'85.
No, it wouldn't make any difference. Possibly the connection to the cat from the y-pipe, that's about all that would change.
What headers are we talking about here?
Transmission: 4L60
ti tech headers and the location is a secret until i buy them
I want smog legal headers b/c i might not live in Ohio for the rest of my life.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The headers themselves are 99% identical for all years. What is different is usually the y-pipe to cat connection. However, the ones made for LG4/TBI engines will have smaller y-pipes than the ones made for TPI/L69 "H.O." engines.
Sounds like Edelbrock TES for L69. The Ti-Tech coating, from what I can gather, is a high temp paint. The 68713 is for LG4 - stay away from them. 68743 is the larger y-pipe L69 application. Both require reusing the EFE valve, so if you get the 68743, you need an L69 EFE valve.
If emissions-legal is the issue, Hooker 2055HKR fill that bill, will use the '86-'90 TPI single cat.
Transmission: 4L60
I also found this http://store.summitracing.com/partde...0&autoview=sku
i could just get any headers then weld these in. It allows for far more applications! (and weld in an 02 sensor bung)
Transmission: 4L60
ya as long as don't live in a state like gayafonia I think I'd be alright. And i would call in some favors to get it done. I used to roof houses so I help reroof this guys house and he'll owe me big! I'm sure he would do it... he likes doing it anyway!
redformula88
Oct 14, 2015 06:08 PM
