headers cause SES ?
Old Sep 25, 2007 | 01:41 PM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
headers cause SES ?
heard many stories that headers will cool the exhaust and the oxy sensor will not run correctly and throw a code also the speed density system will i still be able to run headers?
Old Sep 25, 2007 | 02:33 PM
Pocket's Avatar
Car: 91 Trans Am
Re: headers cause SES ?
Depends what type of headers you buy and where the O2 sensor is located
The problem with O2s and headers is the factory O2 is a non heated unit. It MUST be at 600some degrees constantly to even register. When a custom exhaust is ran, sometimes the sensor gets moved from its original location (close to the engine) farther down the stream to where the exhaust temps have already cooled some. This means the sensor is not getting hot enough to register correctly
Most shortys have a bung in the collector which is close enough to the engine to no cause a problem
Most long tubes do not have a provision for an O2 sensor at all so a bung must be installed somewhere in the Y or farther down stream. More often than not this is too far down stream for a stock unit
Do a search on "Heated O2 Sensors" and retrofitting them to our cars for just this purpose
That should fix all your O2 sensor woes as far as headers is concerned
Old Sep 25, 2007 | 04:21 PM
Car: 1985 TransAm
Engine: 5.0L TPI
i do have a pair of shortys with the o2 bung so i should be " 02 safe " ?
Old Sep 25, 2007 | 06:52 PM
Pocket's Avatar
Car: 91 Trans Am
Should be
If the light comes on (New headers will kill a sensor) after the headers are broken in, then go with a heated unit. Otherwise you should be good to go
Old Sep 26, 2007 | 10:57 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
hey pocket, how long should you break in the headers for?
Old Sep 26, 2007 | 11:13 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
If you gut the cat and run too much of a free flowing exhaust, you can get a SES light. This is due to too little backpressure to make the EGR valve operate properly. I would assume that headers only and a stock exhaust would not cause this.
Old Sep 27, 2007 | 03:02 PM
Pocket's Avatar
Car: 91 Trans Am
I gave mine a month before I swapped a new O2 in
Works fine
FormulasOnly
Jul 23, 2018 08:47 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
