Air/Smog Pump problem
Old Oct 15, 2007 | 07:55 PM
tpimaro86's Avatar
So I bought an 86 tpi camaro with a rebuilt motor, aftermarket headers and I went to get it inspected and they failed me because I didn't have a smog/air pump on the car. I'm having trouble finding out what I need to get and where to get it, and also how it installs/works. Also, do I need stock exhaust manifolds to do this set up? How much $ could I be looking at to do this.
Thanks,
Bernice
Old Oct 17, 2007 | 10:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
What headers do you have? If there aren't any little tubes sticking up from the primary tubes coming off the heads, then you probably don't have headers that will pass inspection. There are several available that do, from Hooker, Edelbrock, and Hedman, to name a few. The "emissions legal" headers, to the best of my knowledge, are all "shorty" style, with a y-pipe that follows the stock routing to the catalytic converter in the stock location.
Old Oct 17, 2007 | 11:20 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Air/Smog Pump problem
Nobody makes replacements, so you're going to have to search the classifieds and hope you can find someone else who removed theirs.
This is why I tell people not to remove their emissions equipment.
Old Oct 18, 2007 | 12:38 AM
five7kid's Avatar
I've got some of the parts available because I'm swapping in a later engine that doesn't need it.
Hopefully the harnessing is still there.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
