Will the Hedman 68491 clear the driver's side engine oil cooler?
Hey guys, I've got a 91 Camaro Z28 with a stock 350 tpi, dual cats, and factory auxilary engine oil cooler located on the driver's side beneath the engine block followed by the oil filter. I contacted Hedman direct in regards to the Hedman TES 68491 header. They told me it wasn't going to fit becuase my oil cooler hoses will get in the way of the driver's side pipe leading to the "inner" (left) cat. So, what modifications did any of you have to make to the driver's side exhaust pipe leading to "inner" cat to clear the engine oil cooler or was the engine oil cooler removed? I am planning on purchasing this set through Jet Hot Coatings, I just wanted to do my research before purchasing this set of headers. Your responses would be greatly appreciated. Thanks.
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
Re: Will the Hedman 68491 clear the driver's side engine oil cooler?
I got headman headers in my car. I got them from Jegs. I dont know the part number off hand but they are the only firebird/camaro with A.I.R. I had to pay my mechanics extra b-cuz the drivers side wasnt going in so well. Passenger side was fine. It took these guys over a week to get the drivers side in WITH care. But they are a popular shop in UT.
I think it didnt clear a brake booster line but I know it was VERY close to the steering column( or whatever its called).
newb here.
newb here.
newb here.
newb here.
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
i put the headman long tubes in my car like 2 yrs ago... my car is a stock 350tpi with engine cooler,.... i had no problems. it was kinda a pain to get them in and i just took the drive one out a month ago and put it back in 30 min.... no probs here
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 21, 2015 09:32 AM
