floor pan mods?
Old Nov 16, 2007 | 07:29 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
floor pan mods?
has anybody here done floor pan mods to better squeeze some mufflers under their car? i just bought a set of true dual that i plan to run with hedman lt's. i am not running a back seat and the metal in the seat pans is rotted. i planned on cutting out a square level with the floor and just welding in a flat sheet of sheetmetal. that should make alot more room for mufflers and maybe free up room for fuel lines, or pump, or filter.
anybody got pics of what theyve done?
Old Sep 2, 2011 | 11:32 PM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
Re: floor pan mods?
I know this thread is old, but this is exactly what I want to do as well. Does anyone have any info? I was going to make a new thread, but this is easier! Thanks.
Old Sep 4, 2011 | 02:11 PM
Pocket's Avatar
Car: 91 Trans Am
Re: floor pan mods?
No pics, but the area isnt hugely structural. Go for it
Just be sure the filler panel is atleast tack welded in. Rivets wont do
Old Sep 5, 2011 | 07:23 AM
Dakota z-28's Avatar
Re: floor pan mods?
I have a 1987 Iroc z and I want to do the same thing. But I want to run three inch exhaust and keep the backseat because I have a daughter. Any suggestions?
Old Sep 5, 2011 | 02:42 PM
Pocket's Avatar
Car: 91 Trans Am
Re: floor pan mods?
The question was about removing the deep pan under the backseat, not the backseat itself. Its not affected
PS, 3" requires no mods to the chassis. Its the most popular size on any 3rd or 4th gen and many MANY off the shelf kits exist
Old Sep 5, 2011 | 05:33 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: floor pan mods?
Long as you use SFC like Alstons that run down the center like the real frame.
There is plenty of room to put bullet mufflers n 3in pipe down the sides of the car, iin that valley where the floor pan and side meet.
See link in sig, where I got my cherrybomb n piping run, plenty of room on the left too but I only run a single.
Old Sep 6, 2011 | 06:08 PM
Engine: 383 Stroker
Transmission: t-56
Re: floor pan mods?
So there is no harm in deleting the back seat pans? Mine are rusted out
3.8TransAM
Sep 17, 2015 02:16 PM
Lanz06
Sep 14, 2015 07:16 PM
machinist21
Sep 5, 2015 03:03 PM
mrdevontay
Sep 2, 2015 08:04 PM
