O2 SENSOR QUESTION
Car: 91 Camaro TBI 5.0
O2 SENSOR QUESTION
HI ALL,
I WAS TOLE THAT O2 SENSORS THAT HAD 3 OF 4 WIRES HAVE A BUILT IN HEATER THAT ALLOWS THE SENSOR TO DELIVER INFORMATION WITHIN A MINUTE. I HAVE THE 1992 V6 3.1L CAMARO THAT HAS THE ONE WIRE O2 SENSOR THAT RELIES ON THE HEAT OF THE EXHAUST TO WARM IT UP BEFORE IT DELIVERED ACCURATE SIGNAL, DOES ANYONE KNOW HOW LONG THAT IS?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: O2 SENSOR QUESTION
First, please dont type in all caps, its rude.
The one-wire O2 sensor works fine with stock manifolds. The 3-wire heated one is for headers when you move the sensor further away from the heads.
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
The 3 wire O2 sensor is also when you have mods done to the car. The heater helps keep it clean and allow you not to have to change it as often. For you application your 1 wire O2 sensor is fine.
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
instead of making a new thread i wanted to add to the question. I have 305 TPI with hedman headers and y-pipe. The O2 sensor is placed on passenger side right after the header and before the y-pipe. Does that mean that it only gets half of the info and that is why i can always smell the car running rich? Also would i need the heated one placed after the y-pipe for it to work correctly? I occasionally get check engine light come up while cruising around 60 mph.
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
HI ALL,
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
HI ALL,
Car: numerous
Engine: ls1, others
Your concern of a rich mixture may be correct if the sensor is bad or weak, or not reaching operating temperature. Open loop will cuase a rich condition. The 1 wire 02 sensors are so cheap, that I'd say go ahead and replace it and see if it helps.If you had access to a scan tool that would be perfect to figure your issue out. Keep in mind that at WOT your car probably will smell rich due to the fact that the ecm usually switchs back into open loop during WOT.
it smells rich when just idling. Just siting in traffic or after 20 minute drive when parked i can smell it running rich. I wanted to get into burning chips and data logging but with lq9 swap that i am planing i don't want to waste money on the equipment. I guess i will just wait few more month and just get lq9.
also last time i checked it was $50 for O2 sensor, which is not all that cheap(at least for me)
If its that rich, you might have a failed injector. You need an ohm meter and measure the resistance of the injectors when the engine is hot. (and off)
They should all be around 14-16 ohms. If any are less than 12 ohms, that's a bad one.
Yes the computer only reads the O2 sensor that is on the driver's side. The computer fires all the injectors at once, so having O2 sensors on each side wont work.
9192camaro
16
Feb 3, 2019 12:21 AM
