can anyone tell me where to find a rear mounted turbo?
Old Nov 21, 2007 | 12:03 AM
spuddud16's Avatar
i've been trying to find a rear mounted turbo for a 3.1L V6 Camaro 1990 model.
can anyone tell me where to find one?
also, what all mods do i need to do in order for the car to handle it w/o damaging anything?
thanks!
Old Nov 21, 2007 | 12:12 AM
spuddud16's Avatar
Re: can anyone tell me where to find a rear mounted turbo?
anyone?
Old Nov 21, 2007 | 12:29 AM
1991ON20's's Avatar
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
www.ststurbo.com
im almost positive they are a utah based company.
give em a shout....they make anything
Old Nov 21, 2007 | 12:58 AM
spuddud16's Avatar
yeah i found them, but i looked on their website and it only list for the ls1 engines and the lt1 engines, i have a LH0 v6 3.1L...u still think they may have one for my car?
Old Nov 21, 2007 | 01:05 AM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Really doubtful. Though it's not like a little fab work wont fix that.
Then you'll need a way to oil the turbo if the kit doesnt already come with that.
Then you'll need bigger fuel injectors and a high flow fuel pump
Then you'll need a custom ecu like a megasquirt or rom tuner so you can control the fuel and timing
then you'll need a wideband o2 sensor so you can accurately monitor your AFR
then you'll need to go to the dyno for some tuning.
Old Nov 21, 2007 | 01:13 AM
spuddud16's Avatar
it's already got a hypertech chip in it, 3/4in roller cam, 440crane stainless steel crank, ported heads, forged pistons, lighter rods and piston rods. 4spd automatic tranny
Old Nov 21, 2007 | 11:24 AM
305q_ta86's Avatar
Transmission: 5 spd
oh, then you'll still need everything i listed, including a way to tune the ecu.
And then you'll likely need a new (larger) mass airflow sensor.
Old Nov 21, 2007 | 12:35 PM
MP81's Avatar
Car: 2007 Cobalt LT
Engine: M62'd 2.2L L61
Transmission: 4T45E 4-speed Automatic
Axle/Gears: Stock
I've heard that the rear mounted turbos aren't quite the best for power - but for ease, they rank up there.
It does come with a oil line so the turbo remains lubricated.
For some more info, here is an article from CHP: http://www.chevyhiperformance.com/te...rbo/index.html
Jeremys87
Jul 14, 2022 09:08 PM
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
antares57
Aug 6, 2015 07:47 AM
