New exhaust: Hooker 2210s and powersticks?
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
im thinking about running true duals on my 89 iroc. I was thinking about getting some hooker 2210s. Is the ceramic really worth all the extra dough?? Jet hot has em for 700+ shipping right now, and I know they are 400 shipped through jegs for painted. So thats like a 350 dollar difference.
So if i put the 2210s in, then I need the s- extensions, right? Then weld in an H pipe. Then I was thinking about putting in some powersticks. What are the longest ones I could get? I want this exhaust to be loud but not insanely loud, I know LT's and 16" powersticks are going to be unbearable. I was thinking like either 20" or 26" (3" exhaust). Then id have an exhaust shop do the tail pipes.
Do I need to get the 3-wire o2 sensor also?
What do you guys think about this, ive seen pics of one guy on here that did it sort of like that, I was going to weld everything myself.. I dont think ill have clearance issues with stock ride height.. Shouldnt be too hard right?
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Re: New exhaust: Hooker 2210s and powersticks?
I will go for 2210's also this winter.
2 options
1- cut the frame like Craig moates did and route the exhaust round the tranny crossmember.
2- Make a new tranny crossmember like some members here did.
If you have a TH700 I would go with nbr 2. My problem is I will swap to a 4L80E so I dont know how that will affect my possibilities to change my crossmember.
I can post some pictures later if you dont find any...
And a 3-wire O2 is recommended.
/N.
2 options
/N.
Car: '89 IROC-Z
Engine: 355
Wait, what cut the frame, new crossmember?? I thought they were direct fit for our applications.. other people said they fit right in.. I have a mini starter and no A/C. Hooker says to jack the engine up 3" and they go right in??
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
they will go right in, but you need to do some grinding see the stickey from traxion up top.....(and maybe a ministarter)
To get ground clearence for the exhaust (not headers) its the options I wrote, search for some pictures you'll see what I mean.....
/N.
/N.
no green
Jan 9, 2016 09:22 PM
Chevykid810
Sep 28, 2015 12:57 PM
