have order the hedman headers!but have a few questions!!
Old Dec 11, 2007 | 03:00 PM
Iroc-Dennis's Avatar
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
hello
i have order today a pair of hedman street headers
http://store.summitracing.com/partde...5&autoview=sku
and i have a few questions!!
must i buy new spark plugs?the short version?
or can i use the normal spark plugs?
must i chance somthing else on my car for build them in?
can i use the original 3" Y pipe from my camaro iroc-z??
gr Dennis
Old Dec 11, 2007 | 03:10 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: have order the hedman headers!but have a few questions!!
You should be able to use standard length spark plugs. You can order a matching coated Hedman y-pipe that will bolt right up from Jet-Hot. I ordered both from Jet-Hot and it included everything necessary for the installation.
Do you need an 02 bung? The headers dont have one. I had to add a heated 02 to the y-pipe.
I wouldnt even try to re-use the factory y-pipe even if it's in good condition. It defeats what you're trying to do.
If it's not too late, I'd cancel the Summit order and order the header and y-pipe package from Jet-Hot.
Old Dec 11, 2007 | 03:22 PM
Car: camaro iroc-z
hello
yes i need an 02 bung!
can i weld a bung on the header or on my Y pipe!!??
and why must i cancel the order by summit!!
i mean that Jet-Hot is a litle bit expensiver for the headers!
and i live in europe the netherlands so i must pay a lot of shipping cost!
and by summit is the shipping cost normal ($126,-) 7-21 days
gr Dennis
Old Dec 11, 2007 | 03:41 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
hes suggesting to cancel your summit order and simply order the headers WITH the nessicary y-pipe from jet-hot. You could just place an order with jet-hot or the y-pipe by itself though. In the end you will probably pay more shipping for two seperate orders though.
Old Dec 11, 2007 | 03:45 PM
Car: camaro iroc-z
hmmz okey i understand that1
but probebly the original Y pipe of my will fit good!
it`s to a 3" pipe!
or i can fix one by my self
gr dennis
Old Dec 11, 2007 | 03:48 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Get the hedman y-pipe....this way you wont have any fitment issues.
MAKE SURE YOU CHECK FLANGE TYPE AND INLET/OUTLET SIZE.
You dont want a 3bolt flange header with a ball and socket y-pipe flange...just so you know.
Old Dec 11, 2007 | 04:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The Hedman y-pipe is a poor piece compared to others out there. 2-1/2" connection to the cat - actually, it eliminates the cat with a 2-1/2" pipe. It's intended for an off-road LO3.
Your original y-pipe will have to be modified to fit to the Hedman hedder collectors. Actually, to any header that doesn't come with a y-pipe.
I'd say cancel the order and get Hooker 2055-1HKR's. Or get 2055HKR's from Jet Hot. Shipping is going to be expensive no matter where the come from.
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Sep 8, 2015 03:38 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
