92 formula 383 in need of good long tubes,HELP...
Old Dec 20, 2007 | 12:44 PM
lt1z350's Avatar
Car: 92 formula, sd,730ecm with $59
Engine: 383/ t-76 turbonetics
Transmission: 700r4 3200 vig converter
I have a 383 with long tubes on it now which I believe were for a lt1 car. I had to cut both frame rails to get them to clear where they taper in towards the trans mount. I am not sure of the brand but fit up top is ok and it is easy to get to most plugs. The worst problem is they are really low and I have closed off two tubes by smacking the ground. I have saw lt1 stuff is lower so I guess one made for the car will be higher? I need a long tube and would like 1 3/4 as the engine really needs is. The rest of the exhaust is 2.5 custom y pipe to a 4 inch mufflex with flowmaster muffler. I see the pace setter stuff is cheap and looked really good on my buddies 96 trans am. L98 stuff any good? Can I run the lt1 stuff? Being around christmas dont have a ton to spend but got to get someting going as the two bad tubes are about to blow out. I am hoping someone has come up with a better header from another car that works and isnt a mint. I have read alot of stickys and other posts and not seeing what I would hope to find as most are with shorties. Any recomendations would be great.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
italiano67
Dec 11, 2016 09:21 AM
toronto formula
Nov 10, 2015 06:17 AM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
