confused on heated o2 sensor
Old Dec 26, 2007 | 07:37 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Sorry to bother, but i searched and kept gettin mixed thoughts. Just a quick question, Can I run heated o2 sensor all the time. As in keeping it powered all the time? I was just going too have the exhaust shop weld it in the collector. I know if I were to run it close to the original spot I couldnt because it would get too hot. But I am runnin Doug's Lt headers also, so t would be farther away.
Old Dec 26, 2007 | 09:30 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: confused on heated o2 sensor
Yes you can run it powered all the time. It doesnt take much power to run, but when the car is off, you're draining your battery.
Old Dec 26, 2007 | 09:42 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
No I mean wired all the time when I have the car running.
Old Dec 27, 2007 | 05:15 PM
Pocket's Avatar
Car: 91 Trans Am
Yes, all the factory HO2s I know of are constant ignition hot
I would suggest adding a fuse for these too
86IROC112
Nov 27, 2015 09:54 AM
85 Jimmy
Sep 30, 2015 07:56 AM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
fonzie85
Aug 13, 2015 11:50 AM
