2460's
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
2460's
From what I've read the 2055 are the way to go, but it seems as tho the biggest reason people stay away from the 2460's is the y pipe...with that said if a custom y pipe was virtually free would the 2460's be a good choice?
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
Re: 2460's
the 2460's are pretty similar to the 2055's in my opinion...how different can they be when they're made for the same application? and yes the better fitting y-pipe is why most people glorify the 2055's. If you can score the custom y-pipe real cheap, the 2055 guys will have nothing on you
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Re: 2460's
awsome...kinda know some people at a shop that will make one up for me while there doing the rest of the exhaust so i figured i would throw the old headers out and go with some new ones but 700 dollar price tag for the 2055 and getting the air caped off was a little to much to swing for me.
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Re: 2460's
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
Re: 2460's
The y pipe is extremely easy to modify (Cut off 2.5" section, install 3" section, and you have a better flowing system then 2055's). If you don't need air tubes, imho 2460's are they way to go.
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Re: 2460's
Thanks...I can probally get the y pipe made for less than I could buy it...what with shipping charges and everything (canada) so it's no problem...I was just wondering why everyone wasn't really using them. They will be my next purchase tho thats for sure.
