single to dual ???
Old Jan 16, 2008 | 06:52 PM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
single to dual ???
ok so i got my 88 and just put a 350 with 083s and hooker 2055s, t-56 trans and now im looking for an exhaust system, i want 3" dual catback, but how do i go about this? i mean what will i need, and can i run the pipes along the factory set up? as you probley can tell i have no clue when it comes to exhaust, thanks for any help
Mike
Old Jan 16, 2008 | 06:55 PM
chevboy28's Avatar
Car: 1992 25th anniversary camaro
Engine: 406
Transmission: t56
Axle/Gears: 410s
Re: single to dual ???
try a search.
Old Jan 16, 2008 | 07:43 PM
DARKmj16's Avatar
Engine: 305 tbi
i did, other wise i wouldnt post, or atleast the search i did i couldnt find what i needed...ok ill do it the hard way, first question, is it possable to run to pipes along the factory set up?
Old Jan 16, 2008 | 09:16 PM
nliang's Avatar
Car: '83 Camaro Z28
Engine: 383 CID - 360whp
Yes, you can run two pipes along each side of the driveshaft. If you consider putting in true dual you should also consider LT header as well, otherwise just stick to the Y pipe. I recently bought the Stainless Work LT headers from Hawks (I had Edlebrock 1 5/8 shorties before) and have my local muffler shop put in a custom 2 1/2 inch stainless exhaust system including dual cats and X pipe. The car now runs so much quieter without and obnoxious fume or loss of ground clearance and picked up close to 30 whp at the end. This is the single best mod I have ever done to my car, it gained even more horsepower than installing the AFR 195 head.
Old Jan 17, 2008 | 09:47 AM
DARKmj16's Avatar
Engine: 305 tbi
o cool, ok so then i can run true dual, but i need to get a muffler shop to run it...that sounds good, but if i go true dual then should it be the 3"or 2 1/2"? i guess the questions now is which is better, and im expecting somehting lik its a personal choice, but i dont now the pros or cons of eighter, so thats why im asking
thank you
Old Jan 17, 2008 | 10:53 AM
nliang's Avatar
Car: '83 Camaro Z28
2 1/2 or 3 inch, that is the question. It all depends on the ultimate goal of your built; if you target up to 500 hp, 2 1/2 inch is more than adequate and 3 inch dual is good to 800 hp. Or put it another way, 2 1/2 inch for N/A motor and 3 inch for blown.
Old Jan 17, 2008 | 10:56 AM
DARKmj16's Avatar
Engine: 305 tbi
oooo ok well im not trying for more then 500, so thank you very much nliang for the help, i do believe thats all for this topic
LT1Formula
Oct 8, 2015 08:34 PM
zman1969
Oct 1, 2015 11:09 AM
