GMMG or Magnapacks?
Old Jan 20, 2008 | 12:21 AM
87_GTA_5.7's Avatar
Car: 1987 Pontiac GTA Trans Am
Engine: Basic Stroked SBC..383
Transmission: PerformaBuilt 700R4 3000 Stall
Axle/Gears: Moser 9in. 3:70s
GMMG or Magnapacks?
Iv got a 87 GTA with a 500 horse small block and I want to know what exhaust to put on it. The car is not running right now and before I had the motor put in..I had Shorties that ran into true dual 2 1/2 magnapacks..they are glass packs from magnaflow..they sounded great..I loved it..should I go with Long tubes streight back into 3 in packs then turn downs under the back seats or do shortys into a y and go with the GMMG exhaust?
Old Jan 22, 2008 | 10:04 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: GMMG or Magnapacks?
Touch choice. I'd say since you've already got the dual exhaust setup, just keep it as is and run the long tubes.
I don't recommend GMMG without a cat as it just flat out sounds better with a cat. Long tubes are a little tricky to run with a catalytic converter(s).
Having said that, a 500 HP engine with shorties, cats, and a GMMG would sound amazing.
I can't decide.
Old Jan 23, 2008 | 03:36 PM
DaSkinnyGuy's Avatar
Car: 1992 Firebird
Engine: 3.1L
Axle/Gears: 3:23
GMMG if you take the y pipe route, know a guy who is making like 600hp with this exhaust in his 35th SS
Classic chambered muffler for the true dual set up. These are the same mufflers used on the gmmg but for a true dual and or single muffler set up.
www.classicchambered.com
Magnapacks are just to deep, Im my opinion they are out.
86White_T/A305
Mar 6, 2016 01:48 PM
FMFRacing88
Jul 3, 2007 12:43 AM
Hurin
Mar 17, 2004 07:05 PM
1988 5.7 Iroc
Apr 27, 2002 10:53 PM
