Exaust questions
Old Jan 28, 2008 | 03:46 PM
Ivelostcontact's Avatar
Car: 1984 z28 H.O.
Engine: 305 H.O.
Axle/Gears: 10 bolt
Exaust questions
I'm about to do a 305 to 350 swap and I was wondering what was a good cheap longtube + y-pipe combo. manifolds gotta go. It's an 84 z28 h.o. l69, putting in a mildly built 350. Has a t-5 tranny. Exaust is stock to the cat (2.75 inch) and then runs through a 3inch to a bullet muffler and then a h-pipe setup, not sure on the Y. Any suggestions?
Old Jan 28, 2008 | 09:36 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Re: Exaust questions
i've gotta see pics of your exhaust, but you have the stock exhaust with an h pipe???????????/
Old Jan 30, 2008 | 12:08 PM
Car: 1984 z28 H.O.
Engine: 305 H.O.
Axle/Gears: 10 bolt
It's not actually an H-pipe. It's just where the main I splits off at the rear into 2. I was half asleep in class when I wrote that.
I guess my real question is, Since my car has the t-5, do I have to find special long tubes, or will the standard hedman longtubes work?
Last edited by Ivelostcontact; Jan 30, 2008 at 12:09 PM. Reason: Automerged Doublepost
Old Jan 30, 2008 | 12:52 PM
Parasoth's Avatar
Car: 99 Z28 / 68 Skylark
Engine: LS1 / 455
I am 99% sure they will fit correctly, but the Y pipe is an issue.
No one makes Y-Pipes for long tubes, so they need to be custom made.
Either a exhaust shop special, or make your own. If you make your own, you can make it tuck nicer and look nicer than a shops. At the shop you run the risk of getting Mr. Iwantthisdownnowratherthantakethetimetodoitright.
Old Jan 30, 2008 | 10:03 PM
ckyfreak2010's Avatar
hey i have a 92 camaro v6 3.1 L RS im trying to find a true dual exhaust for my car without making one and cheaper than $800 would it work it i tried to bolt up an exhaust system meant for a 5.0 on a 3.1...are the mounts different or could it work and if it cant can you help me find one...
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
