Strange scenario.
Old Feb 11, 2008 | 01:52 AM
chevymetal's Avatar
Car: 1985 Chevrolet Camaro IROC-Z28
Strange scenario.
What would one's engine run like if they had shorty headers installed, but ran one side with 3" exhaust, and ran the other as an open header?
I have such a scenario running right now, and am wondering if the engine problems I am experiencing are related to the exhaust, or if it's a different monster all together.
Basically what happened is my exhaust is fairly old, and somewhat rusted. Then when we had the first bad snow of the season, I had to drive the car home, and the snow was high enough to touch my transmission, and exhaust. The exhaust cracked clean all the way around the y-pipe on my passenger side. So the headers flow basically into the y-pipe but there is nothing sealing it. I get a nasty rapid crisp popping sound that almost feels like backfiring when accelerating hard - with a slight miss, and I get a much slower, muffled popping that feels like ignition in the exhaust when I let off of the throttle after a good rev. This only happens under load, in neutral I can rev all day and it sounds great. Any ideas? I've been trying to fix the engine, when all this time it's probably just the exhaust. I have performed a FULL tune up w/ a new coil as well. AC Delco components. MSD wires.
The car is the 1985 TPI IROC in my info. Basically stock, except for K&N CAI, Hooker Shorty headers, 3" exhaust. Also added an airfoil.
Old Feb 11, 2008 | 01:59 AM
creepingdeath's Avatar
Car: 84 Z28
Engine: carb 305
Re: Strange scenario.
Get your exhuast fixed.
Old Feb 11, 2008 | 09:45 PM
chevymetal's Avatar
Cool, I'll see what it costs to get that welded up. Thanks!
Old Feb 11, 2008 | 09:50 PM
Car: 84 Z28
Engine: carb 305
Make sure you use an "H" pipe or "X" pipe if your going with a dual exhaust. Should cost $300+ depending on the products you use and what size the tubing is.
Old Feb 12, 2008 | 01:57 AM
chevymetal's Avatar
I'm just doing a larger than stock exhaust. Single 3" to muffler, dual 2.5" exits.
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
RedLeader289
Sep 23, 2015 06:50 AM
BWilcox
Sep 20, 2015 12:19 PM
///DAN///
Brakes
Sep 17, 2015 07:43 PM
