Pacestter Exhaust!
Old Feb 24, 2008 | 09:06 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Pacestter Exhaust!
I've looked high and low and I can't find a 350 stock with a pacesetter catback. Anyone have a sound clip or personal experience? Yes I've searched.
Old Feb 27, 2008 | 10:13 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Re: Pacesetter Exhasut!
wow bummer. No good review or a flame? no comments guys? common help a brother out, I'm debating dropping 300 bucks. Tell me why I should or shouldn't please.
Old Feb 28, 2008 | 12:22 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Pacesetter Exhaust!
Pacesetter is one of the "low-end" systems, if you know what I mean.
Old Feb 28, 2008 | 12:55 AM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Re: Pacestter Exhaust!
I hear that a lot too, but I am completely happy with my pace setter headers.
Old Mar 11, 2008 | 05:54 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Alright I've given this thread ample time to acquire some quality replies before I ttt it. So here it is TTT. Common guys I'm desperate. Why is it "low end" anyway?
Old Mar 11, 2008 | 06:24 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Anything is better than the drone master. I'm interested to hear this setup too. The price is reasonable.
Old Mar 11, 2008 | 07:51 PM
91birdman78's Avatar
Car: 91 Firebird, 2007 Avalanche
Engine: 355 headman headers 3" magnaflow
Transmission: Automatic
Axle/Gears: 3.42 posi
I just put a 3" pacesetter on my 305. I like the way it sounds. I haven't been able to drive it yet so all i know is that is sounds good revving up and at idle. Ill try to get a sound clip for it. It looks good too with the tips. I think it was worth the money.
Old Mar 11, 2008 | 11:19 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
Thanks man that would be great if you could get a quality sound clip up!
Old Mar 13, 2008 | 01:09 PM
Explosivpotato's Avatar
just ordered this exhaust for my 350, it'll be mated to some hooker 2055s and a catco cat. I'm also interested in a clip so I'll know what to expect.
Old Mar 13, 2008 | 06:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Board went down when I was trying to reply earlier.
I put the Pacesetter cat-back on back in 2001. I never installed the muffler, because the "3-inch inlet" was a 2-1/2" pipe expanded to 3" to fit the I-pipe.
The I-pipe and tailpipes were a nice mandrel bent pieces. Aluminized, no deterioration in the time since, including winter driving.
I sold the muffler to a member here. Never heard back from him what he thought of it.
Old Mar 13, 2008 | 06:50 PM
Car: 2000 BMW M5
Well that answers why almost no one has used this system. Oh well. Thanks for clearing that up. That sucks.
Old Mar 13, 2008 | 10:28 PM
Avernus's Avatar
Car: 1988 Iroc-z28
Engine: 5.7 350
Axle/Gears: 2.77
So this the end of the exhaust system or can it still be installed? Whats wrong with the pipe being expanded to fit the 3"?
Old Mar 14, 2008 | 04:45 PM
http://www.youtube.com/watch?v=EohJH2ALg-I here is a link to how my sounds i will try to get a better one this weekend. I have a mostly stock 305 with no headers. I didn't have a problem with the exhaust going together. Everything fit perfectly. It is 2 1/2 on the outlet end. its not stretched anywhere.
Old Mar 14, 2008 | 04:53 PM
Car: 2000 BMW M5
When he says stretched, he means that for the 3" inlet, it only has a 2.5" pass tube inside. Most cheap mufflers are like this so they don't have to make multiple sized pass tubes. They just make one or two size pass tubes and then expand the inlet sleeves accordingly. What's wrong with this, is that it kills flow. You might as well only have a 2.5" mid pipe if you are going to run a 2.5" phony 3" muffler.
Old Mar 14, 2008 | 06:16 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
Thats very true, its like sucking through a straw, its wide and open then all of a sudden it restricts everything cuz it gets smaller in diameter at the top. same thing pretty much..
Old Mar 14, 2008 | 08:38 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Thats too bad, because the muffler sounds great in that clip! Whats all done to your motor for modifications, 91birdman78??
Old Mar 15, 2008 | 08:16 AM
Its all stock except for accel plugs, cap, rotor, wires and coil. I also took off the stock airfilter and put a K&N open element set up on it. THis fall i'll do the engine swap.
Old Mar 18, 2008 | 10:57 PM
five7kid's Avatar
I stuck the muffler on one header collector on the '57 for grins (curious what it sounded like). I thought it had a nice tone. Disappointing that it had the small 2-1/2" tube inside.
It could be argued that the large 3" I-pipe gives plenty of a "plenum" for the exhaust pulses that the 2-1/2" pipe in the muffler doesn't make any difference. On a stock or mild 305, that's sure to be true. I just didn't want to take the chance with a "healthy" 305, which got upgraded to a 350 later, anyway.
(For the record, I fully disclosed the reason I didn't use the muffler to the member who bought it - he didn't care, he had a stock 305 and just wanted a cheap replacement for his rusted-out stock muffler.)
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
david068513
Sep 18, 2015 10:36 AM
