Catalytic converter construction
Old Mar 26, 2008 | 06:48 AM
Icarus 402001's Avatar
Car: 92RS
Money's so tight I can hear my wallet squeak. I have to get emission legal. I installed a take off cat from 4th gen ,without air tubes of course, 2 or 3 years ago. I'm guessing I could weld the air tube connection onto the 4th gen cat but I don't know where, in the cat ,the air should be injected. I assume it should enter before the honeycomb. Has anyone had an air tube cat cut or rot open? I tossed the old TBI cat long ago.
Old Mar 27, 2008 | 02:11 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Catalytic converter construction
On a thirdgen cat the AIR tube goes in between the two bricks, right in the middle. I've never seen anyone try to do it, though.
Old Mar 27, 2008 | 04:28 AM
Car: 92RS
Thanks for the reply. What do I have to lose,right?
Old Mar 27, 2008 | 01:14 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Its not worth the hassle, unless you need it to actually be there for visual. Newer technology cats will be more efficient at reducing emissions without air injection.
If you really need it to be there, you could always bend the heat shields a little bit, and just jam a piece of tube in there to make it look like its going in!
Old Mar 27, 2008 | 07:05 PM
Car: 92RS
I actually need it to work for emissions testing and I'm trying to NOT spend $$ on a cat right now. So it IS worth it to try. Right?
=slow_90firebird;3694319]Its not worth the hassle, unless you need it to actually be there for visual. Newer technology cats will be more efficient at reducing emissions without air injection.
If you really need it to be there, you could always bend the heat shields a little bit, and just jam a piece of tube in there to make it look like its going in![/quote]
Old Mar 27, 2008 | 07:53 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
pour a bottle of "guaranteed to pass" in, ive tested it myself and it definetly reduces emissions a lot mostly the NOx
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
bjpotter
Oct 4, 2015 07:48 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
