View Poll Results: Which y pipe option?
Keep single cat y pipe, buy high flow cat
45.45%
Buy dual cat y pipe from SLP, buy two high flow cats
9.09%
Have exhaust shop fab up dual cat y pipe, buy two high flow cats
45.45%
Voters: 11. You may not vote on this poll
slp header dilema
Old Mar 31, 2008 | 05:53 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
slp header dilema
As of right now I have the factory dual cats on there. I just bought a set of SLP 1 3/4 headers from a member on here. The y pipe that came with the headers is for single cat.
My three options:
1. Buy a high flow cat and mate the SLP's up to the single cat
2. Buy the dual cat y pipe from SLP and buy two high flow cats
3. Dont buy either, have the exhaust shop that is welding the y pipe build a custom y pipe dual cat y pipe and buy two high flow cats.
My goal for this car is an 11 second time slip.... id be happy with 11.99x
Old Mar 31, 2008 | 07:58 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Re: slp header dilema
Hey man, what made ya change your mind about the slps? I know you sold off that one set you ran. I would stay with a single cat system. Will flow equally as well as a dual cat system + less weight, less cost, more room under the car for sfcs or whatever. How has my old 10 bolt lasted for you?
Old Mar 31, 2008 | 08:46 PM
Car: 92 Camaro
Axle/Gears: S60 373
I needed a new rear end and you had the 10 bolt for sale. I wasnt thinking performance when I traded the SLP headers for the rear end...I was thinking of getting the car to the track. Besides, these headers look better . I didnt even run the set that I sold/traded with you. I had bought those off of 91greenbird, the guy in MD.
The bolt has lasted, but I only ran the car 4 times since your rear end. Didnt notice any acceleration difference from the 9 bolt 277 to the 10 bolt 323 from you. I have 373's ready to put in, but dont know if they would be worth the $500 shops want to charge me to install them.
Old Apr 1, 2008 | 01:00 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Have an exhaust shop make you up a 2.5" dual cat y-pipe with mandrel bends. Its the best way to go. 4 cylinders flowing thru 2.5" is better than 8 cylinders flowing thru 3". The SLP y-pipe and the factory y-pipe are 2.25".
Old Apr 1, 2008 | 10:34 AM
jsnico's Avatar
Car: 87 GTA
For what it is worth most if not all of the y-pipes for either set up are on clearance on thier website. If that helps you out any.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
redformula88
Oct 14, 2015 06:08 PM
Nervous2
Oct 8, 2015 10:53 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
alpine247
Sep 16, 2015 05:25 PM
