need part number for a direct fir cat with AIR
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
I would like to know the part number of anywere for a direct fit highflow cat preffibly one u guys had experiences with an got good power gains over stock.
also could i buy this MPE-23479 (summit) dual cat on my single cat car?
Transmission: 4L80E/4L80E
Don't get a direct-fit for a '91 single-cat. They're only 2-1/4".
You could do the dual cat set-up. But, you'll have to do something about your cat-back as well.
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
Re: need part number for a direct fir cat with AIR
if i did that i would have to buy a dual cat cat back then right? but it wouldnt require no tuning to run that would it?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Get a Magnaflow cat. You can convert your y-pipe to dual cats but it will require custom work from a muffler shop. They will also make the connection to the cat-back so you wont have to change it. However it wont be worth it unless you also get headers and a larger 3" cat-back exhaust.
For a stock exhaust setup, a Magnaflow 2.25" cat will work fine. Part number 94015 for universal fit and 93456 for direct fit.
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
TA8487
Aug 16, 2015 12:21 PM
