dport heads with oval headers... any gasket work?
Old Apr 19, 2008 | 02:14 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
I got a set of 1yr old hedmans with ypipe for $25 ... I cant justify spending $240 on a new set..anyway Ive read posts on using these and some people have problems with blowing gaskets. Is there anything I can do to prevent this even if it does lower the exhaust flow a little? thanks eveyone
Attached Thumbnails dport heads with oval headers... any gasket work?-s6301262.jpg
Old Apr 19, 2008 | 04:08 PM
Pocket's Avatar
Car: 91 Trans Am
Re: dport heads with oval headers... any gasket work?
Use high temp RTV sealant on both sides of the gaskets
Torque the bolts on schedule
Dont be an idiot like 9/10 posters who complain about blowing their gaskets out by not doing them right the first time
Old Apr 20, 2008 | 07:05 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
I was wondering what the best material to use is?...I should have been more clear... I know of copper and paper but are there any other materials that would suit my problem? Or should I just use copper? thanks for the silicone tip though I appreciate it.
Old Apr 20, 2008 | 07:33 PM
Pocket's Avatar
Car: 91 Trans Am
Ive got 3 years on MrGasket paper gaskets
Old Apr 20, 2008 | 08:59 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
which headers and heads are u running... 3 years on paper gaskets seems alot better than what Ive been reading about. did u grind down the flanges or trim the gasket at all?
Old Apr 20, 2008 | 09:41 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
Copper works well. Be sure to preheat the copper gasket so it is soft. Then use a small bed of RTV. You should not have any issues.
Old Apr 22, 2008 | 12:59 AM
Pocket's Avatar
Car: 91 Trans Am
Hooker 2138 LTs stock LO3 engine
I cut the flange out in between the primaries
Gasket is strait out of the package
I did scrap the hooker header bolts for some socket heads
They are very high quality and I use them on all my cars
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
Navy8125
Aug 21, 2015 09:32 AM
89-S-dime
Aug 12, 2015 11:57 AM
