after header install...
Old Apr 23, 2008 | 07:17 PM
iroczcamaro87's Avatar
Car: '87 Iroc camaro
after the SLP header and y pipe install my starter has crapped out. at least i think it is. I made sure all the wires were not touching headers or the block. They weren't. The starter has been sounding kinda weak. Now the starter acts like it doesnt get any juice...im 100% sure it does. I was wonderin what my options are...i was planning on getting a mini hi torque starter and get some type of wrap to protect it from heat. Did the starter go out because of the heat? Thanks
Old Apr 24, 2008 | 02:20 AM
Pocket's Avatar
Car: 91 Trans Am
Re: after header install...
1) How old is your starter, it might just be its time
2) Are you 100% sure you tightened the brass nuts completely, these can fool you
3) Yes starter shields are very cheap and common, order them from summit, JEGS or even a local part store
Old Apr 24, 2008 | 08:00 AM
1. the starter...i dont know i have about 100,000 miles on the car and i have only had the car since it had like 88,000 so i dont know how old it is.
2. the brass nuts on the starter? yeah they should be tight
3. alright sheilds cool that will work.
would it be smart to invest into a mini hi torque starter? or just buy a OE replacement starter? also do you know how to tell how many teeth is on the flywheel. Jegs and summit ask these questions when selecting a starter. Even though i have the year model engine size, etc. all entered in it asks me the how many teeth.
Old Apr 25, 2008 | 10:37 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Probably take off the bell housing and take a flashlight and check the stamps on the flywheel.
That or take the bell housing off and count em yourself. Last time I counted them I used a peice of chalk to mark every tooth as I had counted it as not to miss one on accident.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
