The Butt dyno says....
Old May 2, 2008 | 02:49 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
in the last week and a half i switched from hooker 1 3/4 inch supercomp long tubes w/ d-port, to hedman longtubes w/ 1 5/8 primaries, and redid my y-pipe with the same 2.5" tubing into a 3" to dynomax ultra flow single 3" in/out. The hedmans were a B&#*h to get to fit in the car, grinding the k-member and a arm, and putting small dents in the primaries, installing an o2 bung, also, since i have d-port heads (l98 corvette) i had to file the round hedmans to match. the passenger hedman went in NO problem at all, and the hokers went in out super easy, (t56 so no engine jacking ). both with open headers, the hedmans are quiter, not by much, but you can notice it. running headers only, the headmans clearly have more low end torque, and i did not notice a top end power loss (HSR on a zz4 from gmpp). switching from the two highflow cats and stupid looking y pipe to no cats and linear y-pipe allows the engine to revmuch faster, and makes taking off from a light sooo much easyer another positve about the hedmans is that they have 1.5 inches more ground clearance, and have the ball and socket, vs the 3 bolt flange on the hookers. i kno that for a wild motor, the hookers would be more effective, but for a mild motor, the headmans seem like the way to go if you have the time (and not the money ) i will post befor and after pics of my y-pipe whenever i get them on the computer
morrow
Jan 13, 2024 12:29 PM
Veaceonee
Sep 29, 2016 08:15 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
