Have you done this?
Have you done this?
has anyone tried or is it possible to tie in to my factory exhaust making it true dual? I have the style with the two small mufflers in the rear, that are fed by a y-pipe on my 83 TA, is it possible to run two pipes off my headers to the two mufflers? I am really hell bent on keeping the exhaust like that i could easily get it done another way but i like the way it fills up the rear end with big meats on each side. or is it possible to replace the stock ones with flowmasters as well? I want a viscious sound but dont want to scare the ladies lol
Car: 1989 Pontiac Firebird Formula
Engine: 305 TBI
Axle/Gears: Stock Gears
Re: Have you done this?
Its possible to run true duels but why do it? Unless you have an engine cranking out over 600 hp, its pointless, plus it adds unneeded weight.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
My friend, there are two sticky posts at the top, plus hundreds of other posts on this forum with more info than you could ever need on how to run dual exhaust on a thirdgen. Please
I have read through the exhaust quickly and didnt see an answer, also i want true dual cause i dont like the y-pipe, and i like the sound, i have true dual exhaust on my olds with flowmasters and the car sounds real good.
