lg4 305 without a.i.r.??
i have shorty headers, a y pipe, a test pipe, and a 3" flowmaster cat back ready to install on my 86 camaro's stock lg4 4bbl 305. the headers are non a.i.r. do i have to worry about my car running poorly without the a.i.r.? do i just remove all the a.i.r. or are there some hoses i have to leave there and plug up??
i cannot wait for my new exhaust, please help!
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: lg4 305 without a.i.r.??
Please read this sticky at the top of this forum:
https://www.thirdgen.org/forums/exha...i-run-tpi.html
That's why they're there at the top.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Removing the AIR system will have minimal impact on the carb'd systems. With headers and cat removed there will be nothing left to remain connected. Be sure to place a small bolt in the mounting hole for the smog pump that penetrates the fuel pump rod bore to avoid the Sofakingdom leak.
The carb'd system only diverts air to the exhaust manifolds during warmup. Removing the system should not trip any codes.
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
hey guys- what size bolt (thread size and length) would be needed to plug that hole?
A search of his name and 'smog pump' will hopefully turn up the bolt size. It needs to be short enough not to interfere with free movement of the pump rod. I'm on the way out or I'd look it up for you...
so i tried searching for the size of that bolt for the sofakingdom leak and found nothing. does anybody know??
https://www.thirdgen.org/forums/tech...leak+smog+bolt
Photo is in the attached thread. You may have to dink around with some different size bolts to find one that fits properly.
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
3/8 16 thread short as you can find....(i just found an extra and shortened it) i was told that not all motors have that hole drilled clear through although both my motors have had it
