Fast burn heads what headers?
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Right now I have headmen 1 5/8 headers on my car. I going to swap in a new motor with fastburn heads. I have been searching online, but I cannot figure out what headers I will need to use with these heads. They have D-ports. Can I use my current headmen headers or will I need d-port headers and if so who the makes them that will fit in a third gen. The headmen website is worthless.
Car: 88 IROC
Re: Fast burn heads what headers?
I found the answer to my own question. Hedman does make a D-port shorty header for Third gen camaro's running a Fast Burn or LT1 head.
Part # 68479 - Non-coated
http://store.summitracing.com/partde...5&autoview=sku
or
Part # 66479- with HTC coating
Below are the tech notes from the hedman website for the uncoated headers
Part Number 68479
Product Name Standard-Duty Uncoated Hedders
Application PONTIAC FIREBIRD 1982-1991 283, 302, 305, 307, 327, 350, 372, 383, 40
Auto Trans. Column YES
Auto Trans. Floor YES
Manual Trans. Column NO
Manual Trans. Floor YES
P/S YES
A/C YES
Special Engine Notes D-PORT
Head Flange Gasket 27690
Variations 66479,
Related Products Hedder Flange Gaskets - 27690
Standard-Duty HTC Coated Hedders - 66479
Application Notes: 1. Without smog injection or injection heads.
103. Will fit with angle plug heads (Chevy aluminum only).
121. Must modify rotary A/C bracket.
131. Chevy engine.
15. Shortie style hedder. Maximum ground clearance.
45. Not legal for sale or use in California on pollution controlled motor vehicles.
6. Modification to stock exhaust required to retain catalytic converter.
B. Not applicable or intended for street or highway use. Legal only for racing vehicles which may never be used upon a highway, check footnotes also.
or
Part Number 68479
P/S YES
A/C YES
Variations 66479,
131. Chevy engine.
Car: 86 Trans Am
Engine: 385 Fast Burn
Transmission: 700R4 - stock (eep!)
Axle/Gears: Stock, will upgrade at some point
Yip, same ones I have. I had the coated ones on order but after waiting two months for them I cancelled and got the non coated (68479). I also ordered from summit so be prepared for delivery times set back almost weekly
Original date was a month after ordering, then every week after that it was pushed back another week. Hope you don't get the same as I had if you order the coated.
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Just FYI:
Dyno Don's 1 3/4 shorties are available with "D" ports as well.
TA
TA
Car: 1985 Yellow Iroc Z w/LS interiors
Engine: 305ci 5.0L
If i was you to maximazed the breathing ability of you setup i buy a set of long tubes Hookers 1 3/4 primaries.
evilstuie
Feb 28, 2016 03:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
