longtubes worth it?
Old Jun 13, 2008 | 08:28 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
longtubes worth it?
i am thinking of buying hooker super comp 2210 headers for my car, but i want to know would i see much power gain on my setup(sig is my setup). i would add a.i.r. to the headers to appear legal too. my current headers i have is the hooker 2055 headers. just need some advice..
Old Jun 13, 2008 | 08:51 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: longtubes worth it?
you will see maybe 20 more horse. whats really killing you is the 2.73 gears
Old Jun 13, 2008 | 09:15 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
I think the long tubes are great but you will need a gear in the car also. do the gear first then the headers hedman has a long tube that is priced right at $100.00 1 5/8 tube.
Old Jun 13, 2008 | 10:14 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its not worth the hassle on a California car, as long tubes are not smog-legal. Just get some of Dyno Don's 1 3/4" shorty headers and be happy.
Old Jun 14, 2008 | 08:20 AM
mouthforcombat's Avatar
Car: '86 Iroc Z
I am very happy with my shortys and I think short tubbed headers are fine for anyone who doesn't plan on building their motor to the hill. However, if you're going past moderate modifications (cam, heads, etc.) than yeah, long tube headers will really compliment everything. Kinda a pain for clearance, though.
Old Jun 15, 2008 | 06:35 PM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
Axle/Gears: fact G80 with GT4 3.73
u def need gears. i went with heman l/t's and i lovem. i got them b/c i heard they fit better in our cars then the hookers do but i can't confirm that b/c i never put hookers on one of these. so its just here-say on my part.
all in all i would do the gears first u won't believe the diff. if u go to 3.73's it will feel like u added 60 h/p.
Old Jun 15, 2008 | 07:21 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
What did your dad change over the SLP design? Also, how are you getting by smog with no E.O. numbers? Are you using SLP #'s ? I have SLP 1 3/4 headers on my car now.... Any gains to be had by the headers you guys are building?
Jason
Old Jun 16, 2008 | 10:49 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Originally I just made improvements, one piece flange (3/8th's thick) ball and socket connectors (no gasket needed) redesigned the left header to clear the steering, and made the AIR tubes a direct fit.
Then I saw the need to change the tubes to accommodate all the different spark plugs angles and raised the exhaust ports .100 to fit the raised port heads.
Wella, now we have a header that fits almost all applications and doesn't burn spark plug wires.
I also make a y-pipe that is 2 1/2" into a 3" collector (not 2 1/4")
and dual 2 1/2" pipes for dual cats.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
