How to bolt the oil dipstick with Hooker 2055's
Old Jun 17, 2008 | 07:51 PM
Rich92 RS's Avatar
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Just got done installing a set of Hooker 2055's, on a 92z L98. We ran into a problem, when we tried to line up the bracket on the dipstick to the bolt hole on the header flange. We also had a problem figuring out which bolt to use for that hole. The stock bolt that the dipstick bolts to is to long to use. Its impossible to get that bolt in the hole, because the end of the bolt hits the header tubing. So we used a regular bolt from summit, and the dipstick is just pressed in(not bolted to the header flange). So how exactly is the dipstick suppose to be bolted, and which bolt do you use?
Old Jun 18, 2008 | 06:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: How to bolt the oil dipstick with Hooker 2055's
The following link may (may not) be of help:
http://www.sallee-chevrolet.com/Chev...Z4dipstick.cfm
JamesC
maroe624
Apr 16, 2017 08:29 AM
deracer
Apr 11, 2016 12:04 AM
Navy8125
Aug 21, 2015 09:32 AM
matthew911
Aug 12, 2015 09:38 AM
