questions about glasspacks
Car: 1986 trans am
Engine: 305 5.0 tpi
Axle/Gears: 3.23 9 bolt rear end
hi i have a 1986 trans am it has a 2.5 flowmaster on it but its weak
i wanna put on the loudest legal sounding exhaust on it
im thinking thrush glasspacks,cherrybombs,or magnaflow
anyone has suggestions plz let me know..
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: questions about glasspacks
Classicchambered.com sells chambered exhaust pipes. I got one for my iroc and it is freaking loud (although I still have to finish the rest of the exhaust after the chambered pipe, that extra length of piping should mellow it down some). It's really nothing more than a straight pipe with some baffling.
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
http://www.youtube.com/watch?v=3YjXNMVbWMw
i have a thrush glasspack 2.5" in/ out. i think it sounds great.
as far as glasspacks sounding like cr@p- only the cheap-o ones sound like crap. that's why they're cheap. the thrush glasspacks aren't that much more expensive, but the quality and sound is much better.
chambered exhaust is a completely different sound. personally, its not my thing. seen a bunch of 3rd and 4th gens with that setup.
bottom line- do your research and figure out which you like best. the chambered mufflers are more expensive, but it's worth it if it's what you like
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
A straight-thru glasspack isnt gonna reduce HP any more than any other straight-thru muffler like a magnaflow. The only difference is the packing, the quality of metal, and the shape of the baffle scoops inside.
Its mufflers like a flowmaster, that use chambers, that will start raking up the backpressure.
I suppose I stand corrected.
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
glasspacks have been kicking *** for decades i dont know why everyone hates on them, same people that hate on 15" wheels, white letter tires and air shocks it seems
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Haha, i've got 15" wheels and white letter tires, but no airshocks, my car sits high enough in the rear as it is. Looks good to me though.
Car: '89 IROC-Z
Engine: 355
not meaning to hijack this, but u got ne pics? planning on getting some wheels soon, thinking outlaw II's, centerlines, pro stars or M/T et's. (probably outlaw IIs with radial t/a's, the cheap route)
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
For the record, I just got my exhaust finished. That chambered resonator from classicchambered.com sounds amazing in front of a summit turbo series muffler.
