Will this gasket match?
Old Jul 2, 2008 | 11:06 AM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
I have an 87 TPI with stock cast heads. I also have Hooker 2055 headers. My header gasket has blown out and I need to change it. I have a set of nice Percy aluminum gaskets that are square port 1.5 inches. Will it be fine to use this gasket, or will it hinder performance? I asked this question to a few people and they have said to use "stock" port gaskets, but I dont see much of a difference between "stock" shape and "square" shape. BTW the ones that came with the 2055's are round port and thats what Ive been using. Thanks
Old Jul 2, 2008 | 11:10 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: Will this gasket match?
It won't hinder performance unless they cover the port hole, therefore causing blockage in air flow. You can get them and always trim away excess with scissors or tin snips if need be.
Old Jul 2, 2008 | 02:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
1.5" square might be too big to seal the ports properly. You can always try, though.
I just picked up a set of Felpro 1404's. They do a nice job. I never used the gaskets that came with the 2055's, didn't like the way the partially covered the ports (and the cheap material - one of the nits I have with the 2055's).
sheachopper
Jul 31, 2019 11:27 AM
rusty vango
Sep 29, 2015 02:44 PM
Jonas Earl
Sep 27, 2015 07:39 AM
hdis2002
Sep 8, 2015 02:52 PM
