trouble with headers please help
Car: 1986 Trans AM
Engine: LS1/T56
Axle/Gears: 3.83
i have a 86 TA and have hooker shorty headers, i wanted to get someone to install them but the local shop wants 275 dollars because he said the engine has to be lifted n all this crap, is this true? can i not just unbolt the exhaust manifolds and bolt in the headers? please help, thanks alot@!
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: trouble with headers please help
Do a search on installing headers, see what you think after you've read up a bit.
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
By doing it your self, you will learn alot about your car. How things work, what goes where and when your done you'll get a good feeling that YOU DID IT! but... its a pita to do this swap and yes the motor has to get jacked up, jack up your car on four jack stands for better working space and dont forget about spraying some penetrant to loosen up everything it will make it alot easyer
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
[GA] Shorty headers
Night rider327
Sep 16, 2015 02:20 AM
