y-pipe / maniflod's interchangable?
Old Jul 31, 2008 | 12:00 AM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
I was just wondering, I was thinking of looking for a used factory y-pipe. I want the one from the 85-90 TPI cars, that uses a single 3" cat, and is slip-fit on the y-pipe side, and ball-socket on the I-pipe side.
I was wondering though, would that y-pipe bolt up to my stock LO3 manifolds?
It would make doing exhaust so much easier, because then I wouldnt have to buy all the parts like headers, cat, all that at once. I could get a junk factory cat from the same exhaust system, and hollow it before I put it on the y-pipe. Then, I could keep a fresh 9118 type cat for emissions time. And get any full 3" catback I wanted.
Old Jul 31, 2008 | 12:49 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: y-pipe / maniflod's interchangable?
No. The left side is close enough, but the right side is completely different. You have to swap the manifolds and y-pipe together.
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
Camaro_383
Sep 11, 2015 11:28 PM
hectre13
Sep 8, 2015 03:38 PM
Out-Cast
Aug 22, 2015 07:49 PM
