help with exhaust leak between y-pipe and exhaust manifold
Old Aug 19, 2008 | 05:35 PM
99transamgirl's Avatar
Car: 84, 99 Trans Am
Engine: 305 G, LS1
I have an 84 trans am with rebuilt 305. I have the original exhaust manifolds on with original y-pipe. we had the rest of the exhaust replaced except the cat. b/c it was full of holes and we were tight on money. anyway there is a leak right where the y-pipe meets the driver sided exhaust manifold. the guy at the shop tightened the bolt as much as he could and said if it continued to leak again we needed a new y-pipe and that would fix it. is this true or is there something else I can do to stop this leak at that area. it's very loud. thanks
Old Aug 20, 2008 | 12:14 PM
84chevyz28's Avatar
Re: help with exhaust leak between y-pipe and exhaust manifold
i usally losen bolth sides then try to tighten bolth sides equally that usally fixes it but you have to suport the existing exuast with a jack stand
Old Aug 20, 2008 | 03:51 PM
Engine: 305 G, LS1
the guy at the shop has done it two times now and it has started again. he took a torch to heat it up to try and tighten it even more, but again it has started.
Old Aug 23, 2008 | 05:01 PM
Engine: 305 G, LS1
anyone have any clues? is there a cheap fix I can do? could I use one of those repair kits I've seen in auto store that are some type of putty/ sealer for exhaust leaks or exhaust tape?
Old Aug 24, 2008 | 07:14 PM
Pocket's Avatar
Car: 91 Trans Am
Replace the dounut if its beyond saving, otherwise just load it with red ATV sealant
Old Aug 24, 2008 | 07:40 PM
Engine: 305 G, LS1
thanks, I will try that.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
transaero
Aug 31, 2015 01:14 AM
downsouthboy
Aug 29, 2015 11:29 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
