5.7 vortec, hedman lt's what should i do for exhaust?
Old Sep 13, 2008 | 08:07 PM
johnnyboy's Avatar
Car: '82 formula clone, 95 saab 900se
Engine: 350 vortec'd tbi, 2.0L turbo
Transmission: 700r4, 5 spd
Axle/Gears: 10 bolt 2.77 open
so i've recently swapped in a 5.7 vortec from a 3/4 ton chevy and decided to get the hedman lt's instead of the edelbrock shorties i had. i'm not doing anything crazy performance wise so i'm pretty sure the motor will be in the ballpark of 270-300hp
i'm just curious to see what you guys would recommend for the best sounding and performing exhaust. i could run true duals or make a y-pipe and run a single catback.
i'm no stranger to fab work so it'd be no problem either way.
Old Sep 14, 2008 | 10:53 AM
weinz90's Avatar
Car: 87 IROC, 96 Suburban
Engine: 5.0 TPI, Vortec 5.7
Transmission: T5, Built TCI 4L60E
Axle/Gears: 3.45 posi, 3.73 eaton locker
Re: 5.7 vortec, hedman lt's what should i do for exhaust?
I have a 96 suburban with the 5.7 vortec and I run a dual in dual out flowmaster super 40 and it couldnt sound any better. Its surprisingly quiet on the interior but sounds freakin mean outside. Thats my suggestion.
Old Sep 14, 2008 | 01:47 PM
johnnyboy's Avatar
so you're suggesting i run true duals in to a super 40?
anybody else have any suggestions?
Old Sep 14, 2008 | 10:31 PM
weinz90's Avatar
i would probably run a flowmaster 80 series because it has a very similar sound and would be a much easier install. i would run 3 inch single into the 80 series and 2 1/2 dual out. imho nothing sounds better than a small block chevy with flowmaster exhaust but thats me.
IROCtometal
Sep 20, 2015 11:08 PM
Lanz06
Sep 14, 2015 07:16 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
